farmall super c
Hi, i am looking to put live hydraulics on my farmall super c with a auxiliary valve i guess its called, and was wondering if this is what i need, found it on ebay (link below)i also have a picture of what i know i need and where it should be located on the super c .. all i need to know is is this part on ebay the part i need?
Thanks a ton.
( link image of what i am looking for below)
http://www.google.com/imgres?imgurl=https://photos.yesterdaystractors.com/gallery/uptest/a9411.jpg&imgrefurl=http://forums.yesterdaystractors.com/viewtopic.php%3Ft%3D585995%26view%3Dnext%26sid%3Dd5836324e4f3d9b5a1659c7afbb5d5bf&usg=__xSupvuzblHaAbR72GWBv5lZVtlg=&h=516&w=688&sz=331&hl=en&start=0&sig2=87Sd8-sDktPG6nK3i0zjQw&zoom=1&tbnid=m-g_0xJOMw6EeM:&tbnh=166&tbnw=221&ei=4-9yTPLCIYTGlQeRy_WhDg&prev=/images%3Fq%3Dfarmall%2Bsuper%2Bc%2Bauxiliary%26hl%3Den%26biw%3D1440%26bih%3D653%26gbv%3D2%26tbs%3Disch:10%2C239&itbs=1&iact=rc&dur=84&oei=ju9yTNGvOYTGlQeCzK2wDQ&esq=18&page=1&ndsp=18&ved=1t:429,r:17,s:0&tx=42&ty=72&biw=1440&bih=653
part on ebay
That will not work on a super C You have a live pump on your tractor all you need is a by-pass block to run another impelment. Oldiron29
Go on ebay and look up by-pass blocks for cubs A, B, C, they are different size's go back on fourm and look up by-pass blocks. Oldiron29
so would what your saying i need is something like this? image 1, http://www.vinsonfarm.net/photos/sm_hyd_pump.jpg
Cuz i thought i needed something like this
image 2 https://photos.yesterdaystractors.com/gallery/uptest/a9411.jpg
If you already have the valve for the Fast Hitch, you will need a bypass valve to block the lines to the F-H cylinder and transfer flow to the second cylinder or your quick disconnects. If you don't have the Fast Hitch valve, you will need to get one. Your tractor already has "live" hydraulics. Been out of the business too long and don't know where to find a by-pass valve these days, but they gotta' be out there.
