Farmall Super H
ChrisW
I have a farmall super h with a C-164 motor. i am trying to fix it for pulling so what can i do for the power problem?
You can pull the sleeves and put bigger pistons and sleeves in or bore the block and not use sleeves. You can get your crank stroked, cam reground, head milled or replaced. It is all about how much you are willing to spend. If you have any questions e-mail me.
What kind of power problem are you having? Not enough? Too much? I"m assuming not enough.
The Super H is a very strong tractor when built right. Just run the compression up as high as you can, use overbore sleeves and high-dome pistons to achieve this, then spend the price of a spare tractor ($1500 or so should do it) on your head and you"ll do just fine. Don"t forget to check the clutch to be sure it will hold all the new power. Figure on spending a minimum of $2500 to do it up right, over and above what the tractor cost, and we are only talking about the engine so far! Safety equipment, weight bars and so on will add more $$$, and you will need to AT LEAST take the transmission apart and clean/de-burr every piece in it to make sure it will not fail on you!
It"s a LOT more involved than most people think, or want to do, but if you want to be a front runner, you gotta take the game extra seriously!
Good luck!
P.S Forget about that M comment, I"ll put my H up against one in my classes any time! In fact, the only tractor I pull against that worries me is the H I used last year! I know, but he was family and he wanted to get started and he is only eight...
I pull my H aganst M and other bigger tractors in farm stock & cuts up to 5000 6 mile per hour and hang in there real well.Could pull 5500 4 mile per hour as for as power but am consernd about trans and rear end.
