Farmall Super M
Roy Ward
My question. Is the hydraulic oil and the rear end oil the same. There is a fill hole in front of the belt pully. Is that fill hole just for the hydraulic oil or the rear end also.
What is the weight of oil for Hydraulic and also the rear end?
If the tractor is yours and you intend to keep it I recommend buying some manuals. If you're just helping someone out with their tractor problems there is a Farmall IH forum on this website.
The only transmission fill hole is right by the shifter , it is a 1" pipe plug.
There is "2" drain plugs for the trans, one in the front and one in the rear.
The correct trans fluid level is checked by pulling a pipe plug out of the left side of the trans just back from the clutch pedal.
That trans holds 13 gallons of 90 weight oil.
The best hydraulic oil is I.H hytran it seems to work the best.
As far as a fill hole on the the belt pully, i don't know mine doesnt have one but it is connected to the trans so it is very possible.
If you can't get this answer email me and i know ware one is that has the belt pulley and i will look and get you what you need.
