farmall tractor model and year
stone844
I have a farmall tractor that has no ID plate. I have the nos. from different parts. It has front wheels that are close together and rear has extended wheels for 1 row or 2 row. here are the ones from parts.
block -354898-R2
head -251172-R2
hyd pump-634pa L
hyd resiover-357687-R1
bell housing-351687-R6
left brake housing 355868-r1
right brake housing-355968-R1
any one can help i need to get parts to restore it.
This post was edited by stone844 on 03/14/2023 at 06:30 pm.
354898-R2 is a block that is for a 123cid engine. It could be fit into Farmall and International Super A, 100, 130, C, Super C, 200, 230 and Other Tractor Models. Wheels together would indicate C or Super C If the brake covers are cast (not sheet metal) it is likely a Super C. Some parts are used on many tractors. Jim
(quoted from post at 00:40:21 03/15/23) 354898-R2 is a block that is for a 123cid engine. It could be fit into Farmall and International Super A, 100, 130, C, Super C, 200, 230 and Other Tractor Models. Wheels together would indicate C or Super C If the brake covers are cast (not sheet metal) it is likely a Super C. Some parts are used on many tractors. Jim
Thank you so much. I have started to overhaul the engine and your info will be what i need to order parts.
Suggest looking for numbers stamped in machined surface on right side of block about an inch below head and near front (2-4 inches back?) if it's the engine I'm thinking
of engine model and serial number will be there.
Hello Stone welcome to YT! I see you edited your post,
often that means a new poster has attempted to post a
photo but did not have any success. Here is a copy
and paste that should help with posting photos, if you
were able to edit that tells me you are in Modern View
which comes up in this discussion. At the end of 2022
the forum host here changed the requirements to new
posters to be able to post photos from a post count of
5 posts to 1 post. I believe this change was only made
on ..Modern View.. so you need to post from there. If
you see ..Modern View.. in a gray bar just above the
message text click on that it will take you to Modern
View. In Modern View you will see the Classic View
option in a red outlined box at the top, just adding this
as a way to verify you are in ..Modern View.. Try to post
your picture in Modern. It should go through if you
have at least posted once if everything I understood
about the change is correct. This restriction was a way
to keep internet bad guys from dropping in and posting
bad pictures with hidden viruses. Pictures post
through the ..Choose files.. button or some such name
just below where it says ..Upload Photos/Videos.. down
lower in the ..New post and reply windows, see photo.
They cannot be pasted into the text area as a file. Also
if you are tech savvy and have a smart phone you can
log in to this sight on it and when you click ..Choose
files.. there should be an option to take a photo with
your phone to post.
An alternative is to go to Tractordata .com in the link
and match your tractor to the photos shown there. The
link is to the Farmall models Jim mentioned, the letter
models follow the number models at the bottom of the
list.
Farmalls on Tractor data
I had a chance to look for the nos and it was just where you said. I really appreciate your help. The nos on the pad if i got them right, they were hard to read. Top # was FM 6 or 8 then father over was a G look like. The # under that was 176327. Hope i read them right. Thanks
