Farmall W6 spark problems
Tom Landers
I am working on a 1952 W6. I rebuilt the carb, that works, I put new plugs, wires, points and condenser. It has a distributer and is a 12 volt system. Anyway, I put the distributer back in, set the timing and all that good stuff, fired it up and it ran great for about 3 min. then just died, like you turned the key of. I am not sure what to set the points at, so that may be wrong, but when it was running, it ran great. So if anyone has any info, I would really like the help. I usally work on green tractors but I said I would help a friend. Oh well.
Makes no difference really what color the tractor is, ignition systems are pretty much the same. The trouble shooting sequence you would use on a green tractor will work on a red tractor also.
