Fast hitch plow identification
Lars52
Can someone help identify the model number for this plow and years of manufacture? Also, any pros or cons concerning this plow. TIA
I cant give you the number, but its a early one,later they built one with a spring on top, to provide cushion for hitting rocks and the later one's had the trip back bottoms like the 60 and 70 had!
It definitely resembles the 215 model that has a single point FH used on the 100 through 140 tractors with a rear furrow wheel. I'm not sure if the same model number carries over into a 2 pt hitch model or not.
That looks like a 209. It was also made in a 3 bottom version, called the 309. Then the same plow was made for 3 point and called a 209A or 309A, depending upon the number of bottoms.
