fasthitch adapter?
TimWafer
Just bought a Farmall 706 with a fasthitch. I would like to use my IH 314 rollover plow on it next year but its a 3-point version. What would be the best type adapter to use for this? The one that mounts on the plow or just the arms with the balls and a regular top link to the tractor?
How does the draft work on a fasthitch setup?
Several ways to do it. Just the basic tongs and upper link plate( cheapest,2-300$ but buy quality), Put adapter on plow for three point if you can find one(more difficult to find, more $3-
400, may not be built heavy enough). Completely convert tractor (for sale regularly here in WI/MN border) Most expensive but done for the life of the tractor and probably the best,
thinking around 700$. I am not sure about how much torque on the tipping over of the plow puts on the tractor but the last seems the best solution.If it were not a roll over the cheapest
works very well. The draft thing I would not be too concerned about , it is the tipping over of the plow.
I would use the slide in adapters,they slid into the FH and hook the three point
pins on the plow. I have several for sale, but you must get the ones with the
right width for the pin width. I sold a 300U, and then we spent a couple of
hours getting adapters that would fit his brush hog.
Maybe I need to start with some fasthitch basics first. What should the fasthitch receiver width be from center to center on a 706? Mine measures about 32" but it sounds as if it should be 28" from what I can gather. Looking at the hitch there is considerable space between the receiver hitch arms and the rub plates on the tractor. Could it be someone spread the hitch out to try to make it fit something at some time in the past? If so, I could remove the hitch and probably press it back to the original 28" if that's what it should be. Id like it to be correct. In the deal I also got a pair of new 3-point adapters that have a 2" offset in each. If the receiver was actually at 28" and these adapters used I could get a 32" width which looks like it should fit my plow. Does my thinking make sense?
Any reason I couldnt make my own custom adapters out of some 1-1/4" x 3" bar stock and plasma cut them to shape? Maybe weld a ball socket in the end. Do the adapters need to be hardened or anything?
Yes you can make your own tongs. As far as fast hitch basics there was two drawbar sizes. One for the small (230) and down tractors and the larger ones 240 up. Then there is two thickness
of the larger ones to accommodate the more power full ones, 806 and larger. Your tractor it is easy to buy the OEM top link so I would not even consider buying/making one. Tongs is a
different deal. They make off set, straight, with up ward height addition and more. Some even come with pivots so the width can be adjusted. Me I am used to the short straight "plow" tongs
that came with the 710 plow. good luck..
