FB hack revisited
Not db4600
Well not actually, but the last round was entertaining so let’s do it again.
Not sure if this is for pumping tires or introducing nitrous?
I haven’t seen one of these in years. Surge or De Laval?
1000 watts, 120 volt, 50-60 Hz. Therm-O-Pump..
Appears to me to be a common coolant heater, better known as a block heater.
If it were a cow milker. Why would it be plumbed from the intake to the engine block and have a power cord attached to it?
I grew up on a dairy farm and in the late ‘60’s, when I was a small kid, we had about 25 cows. When the power would go out, we’d hook our Surge equipment ( strap over the cow, milk equipment beneath the cow) to an idling Allis-Chalmers C and get the cows milked.
We later built a different barn, complete with a DeLaval pipeline system. We also purchased a PTO-powered Winco generator.
The system pictured above can also be farmer-engineered to get rid of the air in a cooling system when trying to get all the air out of a freshly built modern engine.
Yep. your pic shows an engine heater.
I/we were takling about the petcock above the carburetor.
THIS valve is what they are talking about! It could also be used to put a vacuum in an irrigation pump to prime it in certain configurations. There was either a glass unit or a float type deal like a shop vac to turn off the vacuum when the water got up to it. If that was overlooked the alternative was bad.
The petcock in OP's photo when turned in on position is a place that can provide vacuum to operate a cow milker while tractor engine is operating
