I dont know the make or model of my fel that is on my 641. It is not a one arm type. I went to use it yesterday to move some dirt and I noticed that after just a couple loads of about a half a bucket full each it was taking longer to lift. On my fourth attempt, it wouldn't lift any more. The bucket tilt still works fine but as of now, I cannot lift the arms to get the bucket off the ground even when empty.
I assume the front mounted pump is working fine as the bucket control still works. So I am thinking that my 2 spool valve has lost a seal on the arm control.
Is it easier to rebuild this, or shiuld I buy a new one?
Unless you all think it could be something else?
hydraulic reservoir is full. 2 cylinders for the arms, 1 per arm. No leaks anywhere in the system. Arm cylinders are gravity drop. No identification on valve, so it might be difficult to find a rebuild kit.
thanks for any thoughts or advice.
