Felt wahers W4 front axle
Klein Rot
Hello
Where can I order the felt rings that are in the bottom of the steering knuckle of a W4. Part number is 53166D
I took old fuel furnace washer layer and split them for it and stretched it over a shaft carefully till it reached the size I needed for the shaft in the tractor. By pulling in the hole and working around I got it big enough to fit the spindle then just cut what I needed to fit the tube. This made a washer about 1/4-3/8 thick and fit good. they just keep the dirt out and the grease in.
