Fence Post Driver on JD 6300
Willow Lane
Location
Central Maine
I'm thinking of buying a hydraulic fence post driver, a Shaver HD10 or something similar, does anyone out there have any experience or wisdom that they could pass on on
these? Also, they want the return line routed directly to the hydraulic reservoir, not plugged into the quick disconnect, so where would I run the line to on a JD 6300
I have a Shaver hd10. It works really good from November till May when the ground is soft. July and August when the ground is hard you're wasting your time. The only negative to these is the spring, I have broke two sets of Springs and on my third set. I buy the Springs from a local garage door company. Shaver makes a springless, they're a lot higher but I believe I would go with that if I was buying another one. As for the return hydraulic line, I put it in the tractor fill opening, I think it is an inch and a half pipe thread on my tractor, I bought a 45 and just screw the return line into it. If you will go to YouTube and look up RDP 58 I have a video of me driving some post on there.
