Fergie t20 head
pr_harvey
Hi, I have a tea20, I ve got to do some work on the engine & in stripping the head off I noticed it s got 5 copper head gaskets stacked up on it. I ve not seen that before & can t think of any good reason it would be a good practice. Amazingly it didn t leak. Any ideas?
I hear heads can be different thicknesses. Do you have head dimensions & corresponding pushrod lengths. I m concerned it could have a short head & long pushrods
The Feguson TEA20 tractor had a petrol engine only and a lot of farmers here in the UK wanted to
run them on TVO like the rest of their tractors. To get over the problem Ferguson offerd a
convertion to lower the compression of the engine witch consisted of a steel spacer plate and two
head gaskets. The convertion also had a small petrol tank for starting witch mounted at the side
of the battery. MJ.
Ah, interesting. Mine could be a tvo then, it has the 2 cap tank and switched fuel tap.
Any way I can tell for sure & should I just put the 5 head gaskets beck on when I re assemble?
I only had to take it off to put in a new end core plug.
I would sure have the head checked for flat!
Running it torqued down on a stack of gaskets would have the potential to warp it or even crack it!
(quoted from post at 18:14:27 08/15/22) I would sure have the head checked for flat!
I m trying to get some specs for the head & pushrods so I can see if it s within the realms of keeping this head or searching for a replacement.
I have no idea how thick the head is supposed to be.
My pushrods are 690mm and my head measures 85mm.
It does look like it s been skimmed before ad the lower edge of the casting is much thinner than the top.
This post was edited by pr_harvey on 08/16/2022 at 06:25 am.
(quoted from post at 14:24:03 08/16/22) My pushrods are 690mm and my head measures 85mm.
No one out there know the different head thickness and pushrod lengths on the Ferguson petrol engines???
Update on mine. I put the head back on with a single gasket instead of the 5 it previously had. And unsurprisingly the pushrods won t install. Before I can get the tappet rail all the way down I m locked out on the pushrods and still 2/8th of sn inch off being home.
I ve heard there are 2 lengths of pushrods for the 2 different heads. I m just trying to find those lengths.
