Got the plugs cleaned and put gas down cylinders.carb has gas.the starter needs rebuilt because it barley cranks with 14v but it did try to fire a couple times before battery died because of starterMaybe it’s your wording, but seems to be getting gas and is getting gas are two different things. Pull the carb drain plug is there gas there? Let it run out for 5 seconds to make sure your gas is continuing to flow into the carb. If so pull out a couple of the spark plugs, fashion a small V trough out of cereal box cardboard print side up. Put about a couple of tablespoons of gas in the cylinders put the plugs back in and attempt to start it. If it runs for a bit on that you have passages plugged in the carb.
A starter that bad is likely a big part of your problem. Get it fixed or replace it.Yes. It will take a charge and also switched it out to make sure with a good battery and really slow cranking and it will drain full battery in 8 to 10 seconds of cranking
I pull start when that happens and see if it will fire up and run like that. If it does you know for sure the starter or the electrical to the starter is the problemThe points are almost new but I still filed them and I get spark between them it does look like a strong spark. And the battery worked great on my cub and could turn it over for minutes if I let it.
Get things back ready to start, including a fully charged battery. Having a hammer handy, start the cranking attempt and simultaneously smack the top of the starter with the hammer. If things abruptly change when you smack it, your bearings/sleeves are shot in the starter and the armature is shorting out to the case....BTDT with a 1963 Ford 4 cyl diesel.A starter that bad is likely a big part of your problem. Get it fixed or replace it.
Not saying I have not hit on starters before, but I will stay with my suggestion that he do some voltage checks, given his description of the problem, before saying smack the starter.Get things back ready to start, including a fully charged battery. Having a hammer handy, start the cranking attempt and simultaneously smack the top of the starter with the hammer. If things abruptly change when you smack it, your bearings/sleeves are shot in the starter and the armature is shorting out to the case....BTDT with a 1963 Ford 4 cyl diesel.
I would say refer to reply 13, he got it started. IMOP meter first or at least a “headlight test”, then possibly a hammer applied with some finesse may be acceptable. My thinking and findings support more of the fact that the jarring from the hammer moves things around in the starter enough to allow a worn out brush to reestablish contact.Get things back ready to start, including a fully charged battery. Having a hammer handy, start the cranking attempt and simultaneously smack the top of the starter with the hammer. If things abruptly change when you smack it, your bearings/sleeves are shot in the starter and the armature is shorting out to the case....BTDT with a 1963 Ford 4 cyl diesel.
I mean you are not destroying the starter, what you are doing is to cause the armature to vibrate and when up in the air on the vibration, if bearings/sleeves worn out is the problem they will show.........like I said, BTDT, Have you"????Not saying I have not hit on starters before, but I will stay with my suggestion that he do some voltage checks, given his description of the problem, before saying smack the starter.
Even a worn out brush is spring loaded....shorting of the armature to the case isn't.I would say refer to reply 13, he got it started. IMOP meter first or at least a “headlight test”, then possibly a hammer applied with some finesse may be acceptable. My thinking and findings support more of the fact that the jarring from the hammer moves things around in the starter enough to allow a worn out brush to reestablish contact.
Sounds like he has starter problems.
