Ferguson No. 21 multi purpose blade
I have a ferguson rear blade (#21?) that needs a lot of work. I inherited it from my father. It had been behind the barn for years.
It is missing the rear cap, and the sliding pin for adjusting the blade angle will not move.
The crank for adjusting the angle of the blade front to rear is broken and is locked up due to rust.
I also have what I think are side extensions for the blade.
Is there a place where I can get NOS or used replacement parts and or at least good pictures of the adjustment crank assembly so I can get started on repairing it?
Otherwise, it is in pretty good shape. I hate to scrap something that looks like it can be restored to a usable condition.
Thanks.
Sorry, I can't answer your question, but a good penetrating oil such as WD-40, or CRC will be a great assist in freeing up rust frozen parts. It requires a lot of patience as you have to apply it to affected parts every day for quite some time in order for it to penetrate well and then use heat on it to help break it loose. It ain't easy, but I have done it.
