Ferguson T20 radius arm bushing replacement
Wisperson311
I have a Ferguson T-20 tractor, serial number 23334 made in 1950. i want to replace the front bushings on the radius arms of the steering system.
How do you take these pieces off?
i can take off the bolts clamping down the tube and take off the hex head at the bottom of the bushing but the bushing won't lift off
thank you
ron
Not sure I'm following the description...
The radius arm goes from the front axle to the pivot ball socket under the running board peg.
The front attachment is a vertical bolt through the arm clevis through the front axle beam. Should be tightened securely, no bushing that I am aware of.
Is this the arm you are referring to? I see a serial number change, so maybe yours is an older model I am not familar with.
Radius Arm
