Ferguson TO30
CKain(MI)
Can someone tell me the coolant capacity of TO30. Also is there a petcock of valve to drain fluid. Or just loosen radiator hose! Thanks
well I think I found the info in another pots here.....
I think there is a 1/4NPT pipe plug, to drain coolant from the block. On the right side of the block, look at the area behind the exhaust pipe if you have a horizontal system. The bottom tank of the radiator should have a petcock to drain it, left side, front maybe.
Book says 10 qts. that will vary some if the system does not fully drain or has build up in it.
