Fiat allis fl14C steering issue
Hello I have a steering issue, the
clutches release and drive well , but
the brake bands sometimes dont work, it
feels like the hydraulic brake booster
isn't working sometimes, and it's
mainly one side, but the other side
doesn't work too once and awhile.
The suction screen is clean, and I
serviced the filter in the top back.
I guess I need to check pressure
somewhere?..could the one booster be
loosing pressure?
Thanks for any knowledge anyone may
have about this machine
If it is like an FA/FL 10 both clutch and brake are run by the same hydraulic system. So if your clutches work the basic system should be right.
Maybe adjustment of the brake hydraulic side? From the manual
Brake rod adjustment on FL 10 is to loosen the adjusting rod lock nuts, turn the rods in till the pedal just comes off its stop. Then
"unscrew it till it contacts the pedal support cross member".
"Then back the rods by one turn". (I assume this means one extra turn to get off the stop in the brake cylinder)
Steering clutch adjustment is 0.5 mm clearance at the stops on the valve body
HTH
