Filling the Fertilizer Spreader...
Bill VA
We have an old Lely fertilizer spreader that must be over 50, maybe 60 years old. It is rusted, but somehow we keep it going another year - every year. We use bag fertilizer as we are not equipped to handle large bulk bags. I could hire the fertilizing done, and might one of these days, but the Lely does a nice job and in spite of the rust, have its accuracy dialed-in pretty good.
The video shows filling the spreader.
Bill
Bill, I couldn't watch the whole video, it made my back hurt just watching it. Do you have an old mower sickle that is broken or wore out? I would suggest placing something across the top of the spreader that will cut the bags open when you place them on top of it. Anything with a jagged edge will do. Would save time having to cut the bags open. Chris
(quoted from post at 11:25:36 03/02/20) Bill, I couldn't watch the whole video, it made my back hurt just watching it. Do you have an old mower sickle that is broken or wore out? I would suggest placing something across the top of the spreader that will cut the bags open when you place them on top of it. Anything with a jagged edge will do. Would save time having to cut the bags open. Chris
hat's OK...if you have seen one bag cut & dumped, you have seen them all! :)
Did ya ever notice how the bags at the bottom keep getting heavier . it's somuch nicer now handing dry fert. these days . Hardest part is picking up the tong and dropping the pin in the hitch , hooking up two hoses and swing out the auger . I picked up a decent gravity box with no gear at a sale for chump change and sealed all the seams with silicone then painted over that found a good ten ton gear at another sale and a hyd auger , best 450 bucks i ever spent . Now just pull the wagon over to the fertilizer plant load and go . When done wash out the wagon and put it away. after watching this i needed to go take a nap .
?Bill, what model camera do you use for your videos??
We use an iPhone and an older camcorder that uses am SD card. I?m looking at a GoPro camera and a DJI action camera. I?d also like to add a drone. The Skydio 2 has my attention.
Thanks!
?Did ya ever notice how the bags at the bottom keep getting heavier . it's somuch nicer now handing dry fert. these days . Hardest part is picking up the tong and dropping the pin in the hitch , hooking up two hoses and swing out the auger . I picked up a decent gravity box with no gear at a sale for chump change and sealed all the seams with silicone then painted over that found a good ten ton gear at another sale and a hyd auger , best 450 bucks i ever spent . Now just pull the wagon over to the fertilizer plant load and go . When done wash out the wagon and put it away. after watching this i needed to go take a nap .?
I don?t quite know what to say. We?re trying to do the best we can with what we have and make it pencil out too. Don?t know where you live, but in my neck of the woods, it?s a haul to the nearest coop and there are steep mountains between us and anywhere. Just to get fertilizer delivered, we have to share a partial load with someone else down the road. Best case is to have a spreader truck come in and do the job, but that?s expensive and we are at the mercy of the coop and their timing isn?t always in our favor. As to fertilizer buggies, we really don?t have a truck to pull one and given our hills, the pucker factor would be off the charts with a loaded buggy behind our tractor on these hills. So we use bags - for now...
Bill
What model iPhone do you have? My iPhone 6 Plus doesn?t take as clear videos, as your videos are. I?m also interested in getting a drone, if you get one, I?d be interested in knowing how it works out.
Now for use it is about 12 miles one way to the fertilizer plant . Now we don't have Mountains to run up and down but we do have some really steep hills that will take the wind out of your sails fast . when i would broad cast with a buggy with my first Pick up even with the 428 under the hood and 4.10 gears i had several hills that would suck the life out fast but we would bring six ton each trip . Then it was the 88Ford F 350 with a 460 then into the cummins with the wick turned up but the hills are still the same . The Teegarden hill , the hill on 518 the Butler grange hill and the Winoa Bridgewater hill yep they will let ya know just how much HORSE POWER YOUR LACKING. And not the hills for Automatics as i have seen several times where and automatic could not get to the top when it was pulled down to torque convert stall speed.. Trust me we know all about cost , probably why we all are driving OLD stuff . My truck is a 95 , my one buddy has a 89 Chevy my other two friend both have 2001 Dodges . Yep we all NEED new trucks but there are two reasons we won't be buying NEW trucks , (1) there are over 54000 reasons i will nor my buddy be buying a new truck and each one is a DOLLAR SIGN and reason (2) is we can no longer get a standard shift . Then with us ya got to factor in our age as we are NOT spring chickens anymore . Not long ago we were complaaining to the feed mill when they did away with the 100 # feed sacks that we got our soy meal in and went to the 50 # paper bags . After my little trip to the cleveland Clinc last May that 40 Lb bag of dog food is about doing me in from the trunk of the car up four steeps and the walk thru the kitchen. .
*9 was my last year with the BAG and then it was only used in the corn planter for starter , that tryen for 400 lbs in the row sucked when you would only make two rounds and have to refill , but still had to either load the pick up up with bags or drag the hay wagon down and load it up and hope ya did not bust the sills out . Us to be really nice around here as we had like four places closee to get fertilizer , one was five miles , one at 8 miles one a 12 miles and one at 15 miles . Now it is the 12 mile one and NOw so is the price war between them. we use the buggy for the N and P and the gravity wagon and auger for the starter , been kicking the idea of going liquid on the planter for ease of handling and covering more ground per fill.
"What model iPhone do you have? My iPhone 6 Plus doesn?t take as clear videos, as your videos are. I?m also interested in getting a drone, if you get one, I?d be interested in knowing how it works out.
Thanks"
I'm using a lowly iPhone SE and if you look at our videos, these are for the close ups, talking, vids from the tractor seat and walking around. The distant videos are the camcorder. The biggest issue I have with the iPhone is the noise from the tractor drowns our the voice audio pretty bad. I need to figure this out - maybe some kind of directional bluetooth mic of some sort - I'm thinking in racing, they must have the same issues just trying to communicate.
Bill
"Not long ago we were complaaining to the feed mill when they did away with the 100 # feed sacks that we got our soy meal in and went to the 50 # paper bags . After my little trip to the cleveland Clinc last May that 40 Lb bag of dog food is about doing me in from the trunk of the car up four steeps and the walk thru the kitchen."
It's funny you mention weight. When we went to a pan kicker on our baler we shortened the bale to help retain the shape when it hits and sets in the kicker wagons. One of the benefits of that is the bales are lighter in weight. We sell just about all square bales of hay to horse customers and they are in worse shape than even me - LOL. We lowered the price accordingly and the women (like my Wife and daughter), as well as retired folks really like the lighter bales. It's not such a struggle for them with our bales - and my back appreciates it too.
Bill
"Now it is the 12 mile one and NOw so is the price war between them."
Our nearest coop is over 35 miles one way and a steep mountain between with crooked roads between us and them.
The next coop is probably 60 miles in another direction and mountains with crooked roads between us and them.
The third coop is even further, probably 70ish miles away. Again - a mountain with crooked roads between.
Between us and these coop areas, there are lots of "horse quality hay", orchard grass, fescue and weeds. Some of it good, a lot of it is really bad hay. The only way we can attract customers to make the journey to our farm (and pay a higher price than the other farms they pass on their way to us) is grow top quality, forage tested hay. We grow timothy, teff and some mixed grass (as our fields age).
That's our niche...
Bill
(quoted from post at 15:14:35 03/02/20) "Now it is the 12 mile one and NOw so is the price war between them."
That's our niche...
Bill
Bill, it has been very clear reading posts from many hay makers here over the years that EVERYONE is in the same niche as you, LOL.
?Bill, it has been very clear reading posts from many hay makers here over the years that EVERYONE is in the same niche as you, LOL.?
OK...
Well Bill, I'm kind of in the "also ran" group! I am fortunate that I'm able to sell my "mixed grass" hay, at a profit, to the same customers year after year.
As for fertilizer, I have the same Lely HR spreader as you, but without the extensions. I buy the 50# bags as well, and ten bags into the spreader is a nice comfortable fill. At 81 years old, after 10 bags, I'm ready to take a rest and drive the tractor! LOL I do save the old back , however, by raising the pallet with the loader as I work down to the bottom, and I don't figure to spread over 1 ton on any 1 day!
?Well Bill, I'm kind of in the "also ran" group! I am fortunate that I'm able to sell my "mixed grass" hay, at a profit, to the same customers year after year.
pallet with the loader as I work down to the bottom, and I don't figure to spread over 1 ton on any 1 day!?
I hope I?m still going at 81, you are an inspiration! We can get 20 bags on the spreader with the extensions, but it?s rounded up.
Thanks!
Bill
Nice video will You show it working to ?
Spreading fertilizer Is a favorite job of mine . Just got off the phone and it looks like spreading fertilizer will be my new career
Yes - I have videos spreading fertilizer. Will be posting them and others as we get into haying season.
I only post a few videos on YT that I think might be of interest, so check back to our you tube channel from time to time to see follow-up?s to this one and others.
Thanks!
Bill
I can buy Planters II and organic fertilizer in one ton bags,use the loader to raise the bag and let the material flow into the New Holland drop spreader.Don't know if one ton bags of regular fertilizer is available would probably be cheaper and easier to handle than 50 lb bags.An old feed hopper to take to the bulk plant and filled then handled with forks on a loader could
work.
