Will Herring
If you have been following my WD hubs saga, here is my final update... As you may know, I ordered new hubs because my old ones were shot. Added new races. Added new bearings. New grease. The works. But still had some play that was giving me grief.
Had a lot of nasty wear on my bearing spacer due to the side to side pounding of the hubs along with stuff spinning that shouldn't be... So a buddy of mine made me a small spacer on his lathe to take up the slop and to keep it so the hubcap wouldn't touch the spindle when re-assembled (as it was scarily close, especially on one side). It's nice because the bearing spacer is essentially 1.500" ID and 2.000" OD, so I was able to find some shim stock that was close as a starting spot.
I used my bearing race installer to install the cup washer seal the proper direction this time.
Everything nicely repacked, tightened down, cotter pinned. Look at that freshly painted hub, I'm sure that will never look this shiny again lol.
After a six hour marathon session this afternoon, I got both sides put back together and got her back out with the mower for the first time in a year! Feels fantastic to finally have gotten this issue knocked out, and the front end is super solid now and doesn't slide all over while driving. It feels entirely different driving now than it ever has; more responsive and easier to hold straight!
Oh, and I put a hubcap off a WC on it to replace that old brazed one that had been sliced through before I got it (probably before I was born honestly).
Thanks for the assistance along the way everybody. It's been quite a learning experience and an adventure!
