I'm a believer. A septic guy taught me how to do it so I could mark all the tiles for the health inspector when I put my house in. The inspector came out and found a tile at every location (12 iirc) I had marked, causing him to allow me to continue to use the existing field and saving me ~$15K for a new raised engineered field.Many people don't believe in the practice to begin with.
Right, And away we go. You are the one saying I am a skeptic. I said "I have seen success and failures. I have seen a dowser give a depth and be within inches to those that miss not only depth but the source being located by a mile or can't tell/don't know the depth." I have not said I did not believe in it. Some people do better than others. I have seen both wires and branches used by dowsers. I have dug by directions from a dowser with about a 50/50 success rate. So, I am willing to see what they locate and say as to where to dig. I have also seen Dig Safe technicians miss the mark with their machines, resulting damaged wires and pipes. Digging around utilities always requires care and attention.I WAS always a skeptic, and you maybe also. But before you cry horsefeathers at the procedure, do one thing. Get two metal clotheshangers and two pop/beer bottles. Bend the wires into 90 degree bends, place one end in the bottle and hold the bottle in one hand. Do likewise with the othe wire. Thus YOU have no control over the movement of the wires. Now move over a known underground wire or pipe. Hold the bottles next to each other in front of you. Watch the wires react to what is beneath you. If they cross over the known object, be amazed. If they do not react then you can say horsefeathers. It works for me, using my hands or bottles, and as I said I WAS a skeptic. Try it you have nothing to lose. and as MarkB says and away we go gobble
Jim please reread my statement, please, I said "I was a skeptic" and you are correct, I did not answer the question if "I" could tell the depth. I cannot. have a great day. gobbleRight, And away we go. You are the one saying I am a skeptic. I said "I have seen success and failures. I have seen a dowser give a depth and be within inches to those that miss not only depth but the source being located by a mile or can't tell/don't know the depth." I have not said I did not believe in it. Some people do better than others. I have seen both wires and branches used by dowsers. I have dug by directions from a dowser with about a 50/50 success rate. So, I am willing to see what they locate and say as to where to dig. I have also seen Dig Safe technicians miss the mark with their machines, resulting damaged wires and pipes. Digging around utilities always requires care and attention.
Now to Dusty's actual question of how to tell the depth. I said I think the dowser has to tell the depth by the force they feel. Non-farmer said he has no clue on depth. What is your method and how accurate are you?
You still have control over the wires. A slight tilt will make them react. Subconscious movement over a known object. Now if you didn’t know where the underground object is you might not have the same experience.I WAS always a skeptic, and you maybe also. But before you cry horsefeathers at the procedure, do one thing. Get two metal clotheshangers and two pop/beer bottles. Bend the wires into 90 degree bends, place one end in the bottle and hold the bottle in one hand. Do likewise with the othe wire. Thus YOU have no control over the movement of the wires. Now move over a known underground wire or pipe. Hold the bottles next to each other in front of you. Watch the wires react to what is beneath you. If they cross over the known object, be amazed. If they do not react then you can say horsefeathers. It works for me, using my hands or bottles, and as I said I WAS a skeptic. Try it you have nothing to lose. and as MarkB says and away we go gobble
Fair enough. When I read it followed by "But before you cry horsefeathers at the procedure, do one thing.", I felt that was seeing me on the skeptic side.I
I don't agree on the control of the wires but that fine....works for me have a good day gobbleYou still have control over the wires. A slight tilt will make them react. Subconscious movement over a known object. Now if you didn’t know where the underground object is you might not have the same experience.
My uncle was a dowser. You can dowse with about anything for about anything and even map dowse. He could use a crystal hanging on a chain and ask questions like depth etc.The depth is something you, the dowser, would tell, otherwise it is dig down until found. Some dowsers (what you are doing) claim to know the depth by the force on their hands from their dowsing rods. Hard to give a fool proof idea of determining the depth. I have seen success and failures. I have seen a dowser give a depth and be within inches to those that miss not only depth but the source being located by a mile or can't tell/don't know the depth. Many people don't believe in the practice to begin with. JMHO
