I use my 8N with a WOODS 660 Finish Mower to mow 6 acres with, not goof-course sod you understand, just plain cow grass, but when kept trimmed, make the land look
decent. We're in the country dude, so never worry about bagging or raking. I'd mow with discharge to the right then follow next row to cut clippings. Normally you want
to to go the other way and avoid cutting twice. I started with a 5' Brush Hog when I first bought the house and property but would do a lousy job and on turns would
scallop the turf. Best to use STABILIZER BARS to help control swaying on turns and avoid scalloping. Best pull in 2nd Gear. If grass is too high may need to make two
passes or slow to 1st gear. In 1st you will take longer and consume more fuel. Oh, yeah, gotta keep your blades sharp too. They are good for 2 or 3 shapenings but plan
on buying a new set at every season. Installing STABILIZER BARS is done one specific way. Once set up, you don't muck with them and are good for every implement you
want to use. Stabilizer Bars often are referred to as ANTI-SWAY BARS. Not to be confused with STAY BARS. Both are completely different items and have totally different
functions. Stabilizer Bars work well with a back blade too plowing snow or dirt.
FORD 8N TRACTOR w/WOODS 660 MOWER:
NOTE: Stabilizer Bars under fender axles to 3-PT.
8N & BACK BLADE w/STABILIZER BARS:
STABILIZER BARS, AFTERMARKET KIT:
OEM DEARBORN FENDER BRACKETS FOR STABILIZER BARS:
FYI & FWIW: STAY BARS:
FYI: IF MEN COULD VACCUM:
Tim Daley (MI)
