firing order on 8n
GPAINTS
you mean the dist.cap is plugged in wrong with wires that could have happened i replaced wires but thought i did it one at a time so i wouldnt screw that up.how do i find the order
[b:2679a11ec8]
Here ya go For the front mount dist.
HTH
Gary[/b:2679a11ec8]
Gpaints - firing order is 1,2,4,3 CCW whether front mount or side mount. If side mount, you may have gotten the cap on 180 degrees out as I believe the cap could go on one of two ways. Rotor should point toward the #1 wire on cap when #1 piston is up to the top of it's stroke. #1 plug being closest to the radiator.
