Fitting a D360 into a 560 tractor?
j carter
Has anyone done this or can anyone tell what problems a guy would encounter trying to do this swap? The engine is actually a bus engine, and was going to run it nonturboed in the 560 if it was a relatively easy swap! Thanks.
If you can find a parted out 666 or 686 with a 312 for parts it shouldn't be too bad. The 312 front cover will fit between the frame rails instead of on top like the 560. Otherwise you will have to devise your own front engine mount. A rear cover from a 766 - 1566 would mate the engine to your clutch housing.
