Five lousy windrows
Fred Werring
Location
Winchester, Ohio
Got off work Friday morning and started mowing hay. Between Friday and Saturday, dropped 40 acres.
Tedded, raked, started baling Sunday, I'm making decent time.
Got to the last field, that I describe as "hateful"...bunch of knots, twists, dips, you're never sure which way to eject a bale so it won't roll into a creek. If it didn't produce so much hay, I'd just bush hog it and be done with it.
5 windrows to go and I'm finally done with first cutting hay, when the baler pickup high centers on a bump as it's stuffed with hay. Broke the shear bolt, jammed it up good.
Trying to get the thing un-jammed, here comes the rain.
5 lousy windrows, I could have been done.
I thought I was gonna make hay without any of it getting rained on this year, but nooooooooo.
Just the way it goes sometimes.
Fred
Yrs back I operated a rd baler for the manufacturer with an experimental driveshaft with a shear bolt for 1 baling season. No thank you I'd rather have a rd baler with slip clutch driveshaft.
Heck, I didn't think we were going to make any hay that was NOT rained on this year... Last weekend got about 1300 small squares and another 20-some 4x4 rounds... Of course it's garbage hay, curly dock... Time to build a weed wiper.
My last baler had a shear bolt, if it ever sheared you had to dump what was in the chamber and clean everything out or it would keep shearing bolts.
Looked into swapping on a slip clutch but never did.
Years ago I had a Hesston rd baler with the square starter roll in the chamber, good baler but if hay was the least bit damp it would warp around that roll and lock up the baler.
Late one evening ground moisture was coming up and thunder clouds where rolling in, I was trying to bale the last windrow that was only 1/4 mile long, might have made 2-3 bales, after a hour and a half of locking the baler up and cutting the hay out numerous times I gave up and let it get wet.
Traded for a different baler not long after that.
