ford8ntractor
What did you have to do to get your fords running?
It doesn't take much to keep an old N Ford running.What did you have to do to get your fords running?
just seeing bc mine needed a lotHello Ford 8N guy, welcome to YT! Sort of an odd first post. I’m taking it from the “extreme” in the title this is strictly a discussion starter post? Or are you actually needing to know what it will take to make your Ford run? Just FYI there is a 9, 2 and 8N section here in the Manufacturers section.
What is extreme? To me replacing a starter, rusted out gas tanks, wiring, engine work, transmission work, etc. are normal maintenance on any tractor the vintage of the Ford 8Ns.Ok, wow, i thought there would be some more extreme stories. I bought my 1948 ford 8n for 600 bucks and the owner said it needed a starter, so i replaced the starter only to find the gas tank rusted through so replaced that as well, i also replaced
1951 8N I bought required the following just to get it running to see what all it did need:What did you have to do to get your fords running?
I've got a NAA. To get it to run, I put gas in it, turn on the key and hit the starter
you ever re-sleeved a tractor?What is extreme? To me replacing a starter, rusted out gas tanks, wiring, engine work, transmission work, etc. are normal maintenance on any tractor the vintage of the Ford 8Ns.
I have re-sleeved several, in frame and out of frame. I have had blocks bored and sleeved that never had sleeves. I did have the shop that did the boring, get and install the sleeves to avoid any "who's fault is it" issues if a fit isn't right (same with having the shop get the bearings if they turn or polish a crank). I have tooling to do a valve job, but if seats are needed, I do have a shop do that. I'm doing an "out of frame" rebuild on a Continental 4-cylinder gas currently.you ever re-sleeved a tractor?
Consider yourself LUCKY if the axle and hub splines are in good condition and stuck together, many are loose and worn out!Since the inside of my rear rims were covered with grease, oil and dirt I thought it best to change the seals on the axles of my early 8 n. I've read in my shop manual that I could pull the axle without too much trouble and I've finally got it pulled but it appears to be permanently attached to the wheel hub. I've tried heat, pounding etc . my dad was a sailor so my next step I figured would be cursing, not that I learned it from him. If anyone else has an idea I'd greatly appreciate any ideas you may have. Thanks
Put it in a press BTDT somewhere on YT I have a pix. Save yer diesel it will be of no help on the hub.Since the inside of my rear rims were covered with grease, oil and dirt I thought it best to change the seals on the axles of my early 8 n. I've read in my shop manual that I could pull the axle without too much trouble and I've finally got it pulled but it appears to be permanently attached to the wheel hub. I've tried heat, pounding etc . my dad was a sailor so my next step I figured would be cursing, not that I learned it from him. If anyone else has an idea I'd greatly appreciate any ideas you may have. Thanks
