Fliud rear tires
Mike L
My M has fluid in the tires.
I filled them with used antifreeze from a
salvage yard it tested at -25 F.
I have a friend that owns one he gave me the stuff for free.
I put it in 55 gallon barels used air preasure
and a lot of luck to put it in.
Havent had a chance to use the tractor yet will find out if it makes a difference in the morning.
I used adapters to go from the 2" holes on the
barrels to ones that will fit air hoses like used on air compresors ran one hose to the valve stem on the tire, clamped it on with a hose clamp.
Put a regulator on the other hole in the barrel
turned the barrel on its side put aprox 10lbs in it this pushed the fluid in to the tire did this until the barrel was empty. I had to let preasure
of the tire ocasonaly to let the air out of the tube.
Be careful to mutch air preasure and the barrel
will blow apart.
