float and fuel level
rocklong
how do u adjust the float level, do u bend the float tab. Also what are the measurements for float level and fuel level in carb
Float setting is l 5/16, carburetor inverted, from float to carb, with no gasket. If I remember correctly the fuel level is 5/8th from top of bowl when float is correct. I do bend the floats by very carefully clamping right behind float with a pliars. It is a picky job though to bend and float has to lay straight so as not to touch side of carb.
