float setting ford 601
Turn the carb body upside down so the float is pressing down on the needle valve. With the gasket in place you should be able slip a 1/4" drill bit between the gasket and the closest portion of the float.
Be certain to set the often neglected fload drop as well unless you want it to flood upon restart after running out of gas or intentionally running the float bowl dry.
Dean
Yes, the float setting for all of the MS carbs used on Hundred and HundredOne series Fords is 1/4".
