Flood Sale---
big tee
This Deere machinery is on the Big Iron auction today. About all it says about them is that they were completely submerged and the oils have been drained. western Iowa along the Missouri river. Lots of $$$---Tee
Notice the bin behind the tractor--Mess
Big mistake to drain out the oil and water and let them sit,should drain the oil and water out and immediately refill(overfill) to stop the rusting.Still probably just parts machines as a practical matter.
The engine is shot already. The flood of 2008 caused about 50 engines to get under water and a few were torn down and full of mud and rust. I had to scrap my tool box because the drawers were so full of mud the slides would not work. A coop bin full of beans had about 5 feet of water on it and it swelled and busted, what a nasty mess.
I have an 8N that was under water and it runs just fine but I did drain the oil as soon as I could then filled it with ATF and filled the cylinders with ATF and drained the hyds and also fill that with ATF let soak a month or so and it runs just fine. Big thing is getting to it fast and flushing every thing out
They were under for several days and probably a few weeks before they were tore down. A few experimental engines were tore down,the rest went to scrap,
Project equipment , IF you want to strip them down to the running gears of a katydid and start from bare castings and built from there , wiring and electronics would be questionable . Back in the eightys while getting and education working in the OIL PATCH i sent a new socalled by his own words the best Cat skinner around out to reclaim a drilling location that had a huge blow pit and i said YOU DO KNOW HOW TO SQUEEZE a pit don't you and i get OH YEA DONE PROBABLY over a 100 of them . Sent him out with a brand new 850 Deere that had less then thirty hours on it and i get a call on the radio not fifteen min. after the low boy driver called me to let me know he was headed to the next move he had that this best Socalled Cat skinner was STUCK . Ok it was not uncommon to get STUCK , i had one low boy setting and one 750 Deere in the yard and NO driver and no operator so this meant i was going to get dirty . Loaded up and went to the location and was unloading when my boss showed up so he and i went back in to the location and at first we did not see the 850 or the operator as he had left to go get lunch ( the local WATERING HOLE ) as we are looking around he shows up and when asked where the 850 was stuck he points to the blow pit and all you could see was about three feet of the top of the rops the vary top of the air cleaner and the top few inches of the exhaust pipe . Atleast he did shut it off . So the fun began , getting the winch cable fifteen feet out to it we needed a BOAT then to get it hooked to the drum on the winch of the 850 was not going to work as he backed in so we had to hook to one side of the blade and he put the blade down in float First try ended in a broken winch line . We needed one more dozer , the boss went down the road and got another companys D 6 D to come up and lend a hand and with two of uws pulling we both broke winch line again we had to go get snatch blocks and this took time all in all the 7850 was under nasty water for close to 8 hours and once up on dry land i had our mechanics out there draining and flushing everything . loaded it up and hauled it back to the dealer to be taken apart down to the frame and have new Hyd. pumps and motors replaced a new engine installed , transfer box totally rebuilt and final drives rebuilt hyd. tanks cleaned out and set back to us only to have nothing but problems with that dozer from then on .
Almost sounds like 2 different kinds of flooding. The first being flash flooding (or near a rushing river?) that churned up lots of mud, and the other being water that had little mud.
Boy that is sad. Parts, hopefully. Forget the electronic stuff. If it was just water, then you might have a chance.
YES! That is what the farmers on both sides of the Missouri river have been dealing with, and are STILL dealing with. Portions of interstate 29 are closed down once again because it is under water.
