Floor jack recomendations
bweb
My floor jack is leaking pretty bad so it's time to start shopping for a new one. Have a 3/4 ton pickup truck so it will need to be a 3 or 4 ton model. Any suggestions? Thanks
I've had a Daytona (harbor freight) low profile 3 ton extended reach for a few years and it works great. Has the quick lift foot pedal as well. They should be going on coupon/special for black Friday or Christmas here soon. I will say the included rubber pad is almost worthless. I cut up an old mudflap and use it if needed.
I also say the Daytona 3 ton from HF is the best deal around. Mine doesn't have the pedal but it does have the dual pump system where it lifts fast with no load then lifts slower with a load on it. I have another jack, about the same size, don't remember the brand, but it's orange and was old when I got it used in about 1989. It worked great until one day it just didn't lift. It always leaked a little but I just kept some fluid on hand to top it off every so often. It is built heavier than the Daytona and doesn't have the quick lift feature, but the saddle is about twice the size of the HF jack. I need to tear into it some day and try to get it working again. I also have a long frame, maybe 5 or 10 ton, about 4 or 5 feet long. It never gets used so it ended up in the scrap iron but I think I'll dig it out since it was working when I hauled it out. Just so big and takes up so much room.
The best jack was built by Milwaukee hyd. Co. but the price was insane $$. The next best was the older Snap-On, hein Warner, Napa etc. jack (same jack, different labels). I bought a hf one cheap and have the old Snap-On version and do like the older Snap-On better.
I have seen YouTube vids on fixing them if you have a mind to.
Otherwise I like the HF 3 ton high lift I got as others say. I’m sure there are better out there if you have money to burn, but it works fine to lift things up.
Paul
It's a Lincoln 2 ton service jack. I called a place that rebuilds hydraulic stuff and they didn't want to mess with it. Where would a person get seals for it? Thanks
I found a kit for my Blackhawk listed on ebay. I didn't purchase it as taking it all apart looks like a pain and it's my spare jack that's over 50 years old.
