farmersamm
The only bulbs with equivalent lumens to the t-8's I'm running now.It's a a few dollars more for the led retro kit I posted. By the time you buy 4 tombstones, a ballast, and two tubes.
Good tubes are becoming a problem. Ballast are also a problem. They last 3 or 4 years, not 30. The LEDs also put out twice the light.
Barrina T8 24W LED Tube Lights 4FT 6000K 3500LM | G13 Base, Fluorescent Replacement & Frosted Cover | TCL24
Easy to Install Barrina T8 4FT Type B LED light Tube are equipped with a double-ended connection and require a simple ballast removal. Please refer to our installation guide for detailed instructions. (NOTE: Our LED tube should only be installed by individuals who have received proper training...
My current fluorescent tubes are around 2500 lumens..................32 watts. So, I guess saving 8 watts per bulb would be ok. But I'm not sure how the LED's handle heat. The ceiling of my container gets HOT.
I'm using 250 watts at present, and plan to add one more fixture, bringing it up to 320 watts. So.........at 24 watts, I'm only saving 80 watts on 10 tubes.
I'd still have to get rid of some of the crappy flat spring style tombstones I have, and replace them with the newer/better versions.
I know that I can't use the standard 1800 lumen things the big box stores sell..........that's a step backwards. But.....I'm not too sure that the 3500 lumen tubes might not be over bright.
