Fluid In Tires
Allan in NE
Well heck,
Guess I'm gonna have to either fill the tires with calcium, chain 'er up or probably both. Can sure feel some wheel slippage going on in the mornings around here. :>(
Allan
Actually,
If I'd just take the time to swap out that bucket for the hay fork, it would make all the difference in the world. But, I don't wanna do that until I get that combine motor planted; need the extra "reach" that the bucket gives.
Little guy does pretty darned good until the temp warms up just enough to make 'er slick.
Allan
Hasn't that thing got a 3 point? Grab the heaviest thing you see for a temp fix. Or find a short little tool bar and hang weights on it.
I've got 1500 pounds of wheel weights on my 856, don't like flats with fluid. I'm too lazy to put my chains on, also I have to go down the highway some, so I put on lazy man's chains, a bale on the back fork. Lee
Allan, before you try calcium you might want to consider windshield washer fluid. That is what my tractor has that I feed with, I still have yet to have to put it in four wheel drive. I don't think it is corosive like the calcium. I am not sure of the weight difference, but it seems to work plenty good for me.
Allen if your running a loader tractor with no Cal. and i don't see enough wheel weights and no weight box You are just asking for BIG problems . One can NEVER have enough weight on the back end when using a loader . As for myself when i had the 2000 I H loader on my one 706 the 18.4x 34's were loaded and had6 sets of donuts on the wheels Plus a home made weight bracket that would take 24 100 lb suitcase weights that went into the fast hitch and sometimes there was a need of more.
Allan I have a suitcase weight bracket with 3 point hookup and it will hold 12 one hundred pounders. If you put that out there on the back end of that hydro I promise you will go where you want to. When your done you set 'em down and ready for summer fallow in 5 minutes. Plus you can move it to whichever rig your using. Best setup we've found for loader work MAINLY MOVING SNOW. Plus I think you have the weights and brackets already? Fluid and chains have problems all their own and efficiency is the word at our age right? Migraine
I put the 3 point bale fork on. With a 1200lb bale on the rear it helps offset the bucket weight. And with chains i can push darn near whatever i want. Works good for poop too.
The 544 has 3 sets of weights on each wheel , plus the tires filled. No traction issues anymore. Have chains hanging if i need them. The new firestones and fluid cured my "cant move" issues.
I personally like just chains. The fluid is so darn corrosive to the rims and always want to eat out around the stems. I have quit using fluid, unless it is in a tractor for doing heavy tillage work. Wet snow, chains!
You're going to need bigger and wider front tires if it ever rains around your place. The bigger front tires will keep the front end from sinking in the ground, which puts a to-and-fro stress on the front end.
Shoot hang something on the tail of that tractor if it has 3 point. What I do is use a back blade and then use suit case weights on the blade. Doing that really adds up fast and puts the weight way out back so as to counter the bale up front. I lift 2000-2500 lbs bales on my ford 841 and don't use chains but I do have fluid in the tires but with out the back blade and the 7 suit case weights on it I still would be dead in the water. Or in other words add a counter weight out back to make up for the weight your lifting up front
Hobby farm
The calcium would be good all year round. That bail is quite a ways into the next county on that loader, which doesn't help any. Dave
Oh yeah, I've got my 16.9 X 38s loaded and several sets of weights too. And I've had a back wheel of the ground a time or two. Pretty hard to get too much ballast on a loader tractor. And to the guys beefing about calcium. I have 60 year old tractors with very good rims that had calcium in all their lives. How long do they think [i:654c4848f0]I[/i:654c4848f0] am gonna last?
I hear ya,
I get so tickled by these guys using the "alternative solutions".
Calcium doesn't cause problems with wheels. It's that bad tube, valve, tire or loose nut behind the wheel that causes corrosive damage.
Besides, think I'd get laughed into the next country if I told the tire shop to "Fill 'er up with anti-freeze." :>)
Allan
Allan, my brother and Dad got together on a solution for a problem similar to yours... it looks something like this:
Of course, takes quite a few calves to pay for something like that...
I knew someone was going to get to belly aching about CaCl again :roll:
The people to laugh at the the ones who keep potential problems around instead of eliminating the possibility of a problem.
Alan, Why not just pick up 3 or 4 more sets of wt? Get 2 pair of splits so you can mount them on the inside and the other 2 pair of solid wt to add to the one wt on each axle you alredy have? And the up side is NO added charge when you need to get a flat fixed by your local tire shop!
We are running 330lbs of inside wt + 450 lbs of outside wt on each rear axle on a JD-4230, open-station. This tractor crow hops more than
I think it should, when the bucket is full of soil or a really heavy round bale on! It needs one more set added to be more right!
I would think that the local salvage yard you deal with should have a good supply at a reasonable price. My guys have them in the $50/set neighborhood. Just my thoughts here, But The Vet and Iowa Lee think like I do. Anyway.......
Later,
John A.
Just a suggestion. Why not a three point bale fork and a bale on it?
You know these tire loading question never end. I hear beer works good. smile
Jim
