fluid in trans. and diff.
Assuming we are working on a TE/TO series Ferguson?
Most run 15w-40 diesel oil in the engine, 15w-40 engine oil in the transmission.
Milky oil in the engine is concerning. Could be leaking head gasket, leaking cylinder liner oring, cracked block.
Milky oil in the transmission is very common. Just drain it, maybe flush it with some diesel fuel. Water gets in through condensation, bad shifter boot, and the top link boot on 35's.
I have had good luck with Tractor Supply Co.
Travellers, Ford all mineral 90 wt transmission fluid
I would not use 80/90
