flushing cooling system when changing the radiator...
My '48 8N's radiator is completely shot, ordered a new one along with hoses and hardware and stuff, from the store at this site...
While waiting for the parts to get here, I got the old radiator off. I stuck a garden hose with a rubber fitting on the top hose connection, and flushed it at high until the water coming out of the water pump was clear.
btw, when I opened the little drain cock on the side of the block near the oil filter, barely a dribble came out. ...ok, went out there again, and took a heavy duty paper clip and poked in that drain valve, and lots of dark grey muddy looking stuff came out and now the dribble is a little better...
SO... is there anything else I can do to better clean out the cooling system? I know some engines recommend doing a 'citrus acid flush' to remove deposits...
Left Coast Geek,Remove the drain petcock in the block and back flush with a 1/4"pipe nipple adapted and attached to your hose..Then flush down the top hose back and fourth to get the junk out.
(quoted from post at 18:33:31 08/06/20) Left Coast Geek,Remove the drain petcock in the block and back flush with a 1/4"pipe nipple adapted and attached to your hose..Then flush down the top hose back and fourth to get the junk out.
thanks... I think I'll order a new drain cock as the one on there is pretty crusty.
(quoted from post at 19:03:40 08/06/20)
eek, I couldn't get the old one to budge, I think I'll leave it alone.
On my 9n,while the head was off I decided to try to clean the water jackets with a small round wire brush. I ran into a goo
that kept covering up the brush,so powerwashed the block's jackets through the water pump[which was off]. Lots of
gunk,probably {radiator stop-leak] came out,and out again.
(quoted from post at 18:33:31 08/06/20) Left Coast Geek,Remove the [b:04a01c47dd]drain petcock in the block[/b:04a01c47dd] and back flush with a 1/4"pipe nipple adapted and attached to your hose..Then flush down the top hose back and fourth to get the junk out.
Sir, would you mind telling us exactly where that petcock is? For the life of me I don't see one on mine, or in the books.
I need to flush mine, too.
Thank you!
(quoted from post at 16:10:56 08/11/20)
Thank you!
the block drain is on the left side of the tractor, midway between the oil filter and starter.
my old radiator didn't have a petcock or drain of any sort, however.
That I found, thank you. I was looking for a petcock....
The radiator on my '50 has an old, brass petcock. It was clogged good, too.
