Thanks for you reply.Like you the small tires were a waste of money so I went with solid tires and have not had anymore problems. Wheelbarrow, small wagon, and two wheel hand truck have all carried heavy stuff and shown no weakness.
I don't think putting foam in those HF tires would help for long as the tires would fall apart until you just had foam!I have several small carts/garden wagons that the tires are always going flat. Some due to cheap horrible freight tires. Has anyone used that foam you fill the tires with and how well did it work? Also is one brand better than another??
Thank you
Jon
I tried using great stuff on small tires. Not a good idea, it didn't cure inside the tire.I have several small carts/garden wagons that the tires are always going flat. Some due to cheap horrible freight tires. Has anyone used that foam you fill the tires with and how well did it work? Also is one brand better than another??
Thank you
Jon
Local tire shop said they have some stuff they use. I have to get the tire(s) to them on Thursday and pick them up on Monday so they can cure.I tried using great stuff on small tires. Not a good idea, it didn't cure inside the tire.
I've bought airless wheelbarrow tires from Menards.
I have small tires off push mowers. I've been thinking of using them to replace the small tires on my hose reel with them.
The stuff at the tire shop will work just fine. Keep in mind it is relatively heavy, and if you ever want to take the tire off the rim you will have to cut it off. If the cost is ok go for it.Local tire shop said they have some stuff they use. I have to get the tire(s) to them on Thursday and pick them up on Monday so they can cure.
He said they will still have some flex to them. Not sure how much it will cost tho.
Jon
Yeah the stuff they use is like a soft rubber. Take a look at a couple of videos of foam filled tires being dismantled.Local tire shop said they have some stuff they use. I have to get the tire(s) to them on Thursday and pick them up on Monday so they can cure.
Jon
