foliar feed
stonerock
have tried many years on corn and beans, several different types, one qt per ac, two qt per ac, split fields in half, every other sprayer pass, still in the combine the moniter shows no difference on both machines. does anybody have any luck with this?...corn and beans not grass
I use Neptune's Harvest Fish/Kelp blend on vegetables,grapes,blackberries,etc keeps the plants healthier I think and things like tomatoes set more fruit.Of course foliar feeding is only as good as what product you
are using.
I think if you have everything in tip top shape, a little boost from foliar can bump things up a bit. But it doesn?t pay on commodity crops, you need a higher dollar crop.
Alternatively, if you have poorly fertilized crops, a foliar will perk them up a bit and you will feel it really helped. They look better.
In either case, money is best spent getting your soils in a well balanced state and address shortfalls with cheaper soil applied fertilizers. Do soil and tissue tests to learn what you are short on.
Then, in high dollar crops or where looks count more than volume, a foliar might pay. But, you are paying the most for getting the least amount of fertilizer so you need a reason for such a small shot.
Foliar is like a bandaid for a little scrape, don?t hope to use it to fix a broken leg type of deal.
Paul
The general talk around here is foliar might return enough to pay for the product and application. I gave it a try this year. Had to spray a fungicide so a foliar was thrown in. I am not holding my breath.
IF your fertility is in good shape I do not think you see any gain from foliar feed products. Maybe in stressed conditions you MIGHT see some results. Even then I think they are largely cosmetic and do not show a yield gain.
Foliar feed products seem to work well for the person selling them. LOL
I have not noticed any difference using them but putting 28 into the irrigation really seems to make a difference especially this year with a wet spring .
