Dale Logerquist
Hello, I just wanted to follow up with it issues of a solenoid problem I had yesterday. With all of your help I had finally decided to take off the new solenoid and put it on a meter. However I ended up droping it and cracked the housing open to discover the larger post was turned and was contacting the other leads. So off to TSC to get another new solenoid.... installed like it should and still no go. I just tested it this morning on the tractor. I removed the two smaller wires and just left the two main post connected. And YES I am getting power to the main post but through the solenoid and all the wat to the starter. Now here is my new problem - This 9n is Neg gounded with power to the 12 volts to the starter I should be turning over or is the starter now deceased? Is it possible to get bad solenoids like this? Should I even try another solenoid? Any Suggestions. Thanks Dale now under 6 inches of snow.
