for 2n starter ?
Removed starter turned by hand kind of stiff. Worked back
and forth by hand seemed to get easier can i spray
electriccleaner in starter to clean under brushes. I also put a
drip of lube on front bearing should i have done that seems
to turn smother.one of the brush cradles rivite through
bach are lose insulation is deterating.i removed starter
because starter switch was smoking . When i would try to
roll tractor by hand in gear motor would not budge
removedstarter and motor would roll over. I read dells
preveous post on starter very helpful .he said clean bedix
should i oil it after
