Kelly in tx
I posted in the Farmall/IHC forum. I have a 55 year old machine. It has been sitting about ten years. I've replaced some zerks, but can't seem to get grease into places it needs to go. How can I get grease into this machine?
only way I find affective is to take it apart and clean out the old dirt/ dry grease, and use wd40 or diesel and then re grease.I posted in the Farmall/IHC forum. I have a 55 year old machine. It has been sitting about ten years. I've replaced some zerks, but can't seem to get grease into places it needs to go. How can I get grease into this machine?
I have one. I use ATF fluid in it. It will work about 75% of the time.
I agree.only way I find affective is to take it apart and clean out the old dirt/ dry grease, and use wd40 or diesel and then re grease.
Take the old fitting out, spin a appropriate size drill bit in the hole with your fingers while pushing in. Install new fitting and try greasing it.I posted in the Farmall/IHC forum. I have a 55 year old machine. It has been sitting about ten years. I've replaced some zerks, but can't seem to get grease into places it needs to go. How can I get grease into this machine?
I would add that if the joint or bearing can be moved while pumping in grease after cleaning as you suggest it will help.Take the old fitting out, spin a appropriate size drill bit in the hole with your fingers while pushing in. Install new fitting and try greasing it.
The difference is the specific application. On swivel joints like excavators etc, you pump grease til the extruded grease is clean. Which does push out abrasive dirt. The tiny bit that was pushed in with the grease in minuscule compared to what was pushed out.I don't get the general consensus about how clean grease is forcing dirty grease into the joint. The dirty grease / rust is already there , that's why the problem exists in the first place. Besides lubrication, the other purpose of grease purge the joint of dirt.
Because an actual precision bearing; roller, ball, tapered, etc. are typically sealed or at least shlelded, the small clearance of the seal or shield "filters" the dirt out off the escaping grease, leaving the dirt in the bearing. There are also many spaces in this type of bearing, the grit gets stuck in a small space, the grease simply flows past it. Forcing enough grease to flush out ALL of the grit into this type will often blow the seal out of place.Why will dirt stay in the bearing? The flowing grease won't carry it out?
A friend of mine had one of those, I think he said he put diesel fuel in it and hit it with a hammer, seems like a simple solution!
Even sealed bearings with no provision for greasing have nothing more than outward- pointing rubber lips for seals... called exclusionary seals. Same for ordinary pillow block inserts. They have to be this way so that the bearing does not suck in any moisture that may be present, as the bearing cools.Forcing enough grease to flush out ALL of the grit into this type will often blow the seal out of place.
A few points.Even sealed bearings with no provision for greasing have nothing more than outward- pointing rubber lips for seals... called exclusionary seals. Same for ordinary pillow block inserts. They have to be this way so that the bearing does not suck in any moisture that may be present, as the bearing cools.
The point being, the outward facing lips readily allow grease to flow out, when the bearing is equipped with a means of lubrication, so that impurities can be expelled.
How many laborers on a jobsite do you think take great care on how carefully they administer the the grease so as not to blow a seal? They don't have the time or the inclination to do anything but to pump grease in until it comes out somewhere.... and the bearings cannot be designed to where the slightest mis-step by maintenance personnel will blow it apart.
