Ford 1120 hydraulics
Jim R Wilson
I have a Ford 1120 compact tractor I just bought. It has a belly mower and I have also attached a bush hog via the rear PTO. It is clear that I can run the belly mower or the bush hog, but not both at the same time. My question is: can I separately raise or lower the belly mower without raising or lowering the bush hog at the same time; i.e., I would like to have the belly mower as high as possible while using the bush hog at a low setting.
Not without re engineering the lift. Thr 3point lifts them both or lowers them both. You might be able to chain the belly mower up depending on the belly mower linkage.
