I picked up a 79' Ford 1300 4wd with a Schwartz 1200 loader locally. It it is in pretty rough shape but Everything worked and I like a project so here goes.
Repairs List:
1) The bucket tilt cylinders need new dust seals & packing, the chrome on the rod looks to be in good shape.
2) A hardline has a small crack next to fitting, I suspect PO didn't double wrench when tightening. (brazing)
3) Hydraulic system has water in it so that needs to be dealt with
4) Front axle has fore-aft play when steering. (is there a bushing for this)
5) General lube and filter changes are needed
6) New Tacho/Hour meter (anyone have some insite here?)
7) Headlights sometimes work (switch?)
8) Horn does not work
1,2,3 Will be done all at the same time for obvious reason.
It is quite a bit down on power compared to a family members Ford 1000 (16hp vs 25hp). I found a turbo that looks like it may bolt on where the muffler is. An engine swap does not seem worth while but a few hours of fab work and a turbo would be a nice bump in power.
MOD List:
1) CUP HOLDER
2) Onboard Toolbox
3) IHI Turbo
4) Pump adjustment to increase fueling
I will update with Pics hopefully soon, need to find a better image host.
Repairs List:
MOD List:
1) CUP HOLDER
2) Onboard Toolbox
3) IHI Turbo
