Ford 1500 injector
bc
Hello guys. Got some water in my diesel fuel tank and that shut it down. Cleaned it all out of the filter and sediment bowl. Bled it down and it hasn't started yet. When cranking on it with fuel nuts loose it is blowing compression back through one of the injectors. Have less than 10 hours on the injector rebuild. Any ideas? Thanks.
Thanks. What is the fix? I got it running again for a hundred feet and it quit again. Going to refill the tank and check or change the filter tomorrow and bleed it again. Of course its down in the weeds in the south 40.
I called the diesel company the rebuilt my injectors. They said to bring them in as there may be a seal leaking or something. He said a stuck injector like that could burn out the piston when run like that. So I'll take it in Tuesday. Although I did mow a couple hours with it after I got it started and it actually ran better and powered it's way up slopes and went through the 6 foot tall weeds better than before without bogging down as bad.
