Ford 1600 remote hydraulics
NBFarmboy
I acquired a nice little 1600 diesel a month ago, had to completely rewire it, as the previous owner had..... problems with factory wiring haha. Now that I'm at the point where the tractor starts runs, and charges I'm looking to add a set of remotes to it, for lifting my Tedder to fold it
Having a very hard time locating a block to go on top of the hydraulic control valve for the three point
Can anyone point me towards a source, or have a picture of one at least???
Thank you
Thank you sir, I had been unable to find that diagram, I'm not great on the internet
Now I'm finding that the part is out of production, not that I am surprised
I will have to try to find one somewhere
Does the tractor have a loader on it? If not you could plumb into the block that the loader valve uses. If it does have a loader you could set it up to use the loader control.
Mark
Does not have a loader, not sure what you mean however, is that something that can be done with the normal control valve for the 3 point??
I just got to look at the original valve
There is nowhere I can see where I could plumb lines into the tractor as is
Will try to get some pictures tomorow
My phone is being stubborn and will not let me upload another picture
That's what I have, that from the top
I have searched up and down, I can't find anything to hook up to
What am I missing here???
After looking at your photo and what is on my 1600, The top plate on mine is different. What I have is a piece of 3/8" plate (steel) bolted to the control valve drilled and tapped for 3/8" FPT. These are connected to the two spool loader valve. The hoses must be connected together if not on the loader so it can circulate/bypass.
I should have noted that the two tapped holes align with the two ports on the top of the valve. Personally, I like my 1600. It is a pretty handy little rig for digging post holes, and small stuff like that. I've even run a 7 ft. 501 sickle bar on it.
(quoted from post at 16:32:33 04/02/17) After looking at your photo and what is on my 1600, The top plate on mine is different. What I have is a piece of 3/8" plate (steel) bolted to the control valve drilled and tapped for 3/8" FPT. These are connected to the two spool loader valve. The hoses must be connected together if not on the loader so it can circulate/bypass.
I probably will have to make something similar
