Ford 1801 (Select-O-Speed)
Ken Shine
I just bought a 196? Ford industrial with back hoe and front loader. It has a select-O-speed. I need to add fluid to the rear end but need to know if tranny and rear end run together and share fluids like other ford models do. Don't want to damage either by using the wrong fluids. I have not purchased a manual yet.
Help needed, Thanks
SOS does not share oil with the rear end. They are seperate boxes. However they use the same oil. Look for a UTF meeting Ford 134 specs - it will say so on the jug. Then change them both.
If you have a front mounted pump/loader/reservoir you can use it there too. And the power steering.
Ford made it easy that way.
