Ford 1910 Differential Fluid
Gabe L
Location
Ohio
Hi, I have a Ford 1910 4WD and i cant find what differential fluid to use for the tractor. If you know what fluid to use please let me know,, Thanks.
Its a common sump tractor and shares the same oil used in the hydraulics and transmission. Any quality brand of universal tractor transmission fluid is acceptable.
Dan
As Dan said, the transmission, hydraulics and rear axle are all one common sump. For that you should use a UTF that says on the label that it meets or exceeds the Ford/New Holland M2C134D specification. For the front axle, since is is just gears and bearings in there, you could probably use a gear oil, but if you want to go with a single fluid for everything, you could use the same UTF that you need to use in the rear axle, trans and hydraulics.
