(quoted from post at 16:49:53 05/03/15) 860, is a 5 speed live PTO
(quoted from post at 10:18:28 05/04/15) Thanks for the info thus far:
During the blasting of the sheet
Metal I did fined remnants of a power
Master decal on side and model 860 on the
Dog leg.
1 I thought 860's had a two stage clutch.
This tractor has a single stage.
2 if the tractor had a transmission swap
It had to be at the factory, so would have
They stamped it twice at the factory?
Thank you so much for the info
And please keep them coming.
Jeff
(quoted from post at 09:33:56 05/04/15)(quoted from post at 10:18:28 05/04/15) Thanks for the info thus far:
Dog leg.
Jeff
What makes you think that if the transmission was swapped that it had to be done at the factory? Has that tractor been in your family since it was new and you know for certain that the transmission has never been replaced since the tractor was bought new? If not, then it could have been changed at a dealership or by a previous owner.
Since the original numbers were stamped onto the replacement transmission my guess would be that it was done by a dealership.
(quoted from post at 11:20:16 05/04/15) the factory serial number had the diamonds at either end.
If I had to venture a guess, especially because you are saying you found original 860 decals on the metal
your tractor was originally an 860 and at some point, someone swapped the trans with one from an 850, and they restamped your serial number above the old number.
since the other number is 850-l, that would be the LP version of the tractor, are they any components of the LP system on your tractor? if not, then I think that's further proof of a trans swap
