Ford 1974 3000
Crowning
Pulled front hydraulic pump to replace 2 fan belts one being spare. Removed about 6gals. of hydraulic fluid and only took 4gals to full and no front hydraulics up or down movement.
Putting about 5 psi of air pressure in the reservoir will help it prime, and make room for the
remaining oil. Do not think more is better. When you have some pressure in the system, work the
valving with it running to let trapped air get out of the system. It could take several minutes.
Pulled out the front pump far enough to replace fan belt ( another belt just in case for back-up) and removed both in /out hydraulic metal lines, added hydraulic fluid that was lost approximately 5 gals. Tractor running no lever action up or down. Hopefully pump is ok. Maybe needs primping
Any advice would be helpful
I believe the reservoir is behind the right heel and there is a 3/8 overflow. Is this the 5psi of air location? Thank you
