TX Ford 2000
Looking for some advice on where to start looking for problems in the hydraulic system. I have a 1965 Ford 2000 (3 cylinder, gasoline). The tractor has been sitting up for a while. The lift arms on the 3-point appear to work fine while not under a load. Once a brush hog is attached, it will lift and lower the implement. But if you try to hold it a a certain height, the arms will slowly lower until the rear wheel is on the ground. At that point, you can hear the hydraulics system giving it a bump every 5 seconds or so and it will keep the front of the brush hog of the ground, keeping it from setting it all the way down.
I changed out the fluid for the rear end/hydraulics. I am still learning about tractors and have a long way to go, but would appreciate any advice on where to start looking/working. Thanks.
