So, I took the dash panel out of the 2000 and found no connections. When the 2000 first took up residence in our side yard, I discovered a rat nest under the cowl on the tank. I pulled and blew out what I
could until a later time. Which is now. After removing the panel, more nest was removed including the petrified remains of the culprit. Got all that out of the way and on the burn pile, then back to the
nightmare called wiring. Close inspection of the wires showed Brer Rat had been busy indeed. Nips and chews all over. I broke out my wiring odds and ends and decided not to use liquid tape but to butt join
all that I could. Analysis shows that on this tractor, wiring consists of 12, 14 and 16 gauge wire to the panel, light and ignition switches, loomed together from an 8-pin connector at the firewall. The
ignition switch has five tabs, including two two-tab fixtures and a single tab. The ignition switch is fed by two 16 gauge wires and three 12 gauge wires. The light switch has four tabs, one two-tab fixture
and two single tabs, with a two-wire feed to one of these. The light switch is fed by two 16, one 14 and one 12 gauge wire. If I err on gauge size I welcome correction. The firewall plug has eight incoming
and outgoing wires as follows: four 16, two 14 and two 12 gauge wires.
At some point in its life, the electrical system has been upgraded to an alternator. There were two wires running from the firewall plug to the alternator, one 16 gauge and one 10(?). There are no
connections of any kind to the voltage regulator. There is no connection to the firewall ground bolt. There are two 14 or 12 gauge wires running from the plug to the starter solenoid. All other wires are
cut and missing. And that concludes my message at this time. Your observations, critique and remarks are welcome.
