ford 2000 missing at a higher idle
billb7984
Location
michigan
hello , I finally got my starter problem straightened out, but I am having a little issue when I run the motor at a higher idle it isn't smooth , I just started putting rec fuel in it , should I go back to reg no lead?
The difference in gas shouldn't be an issue unless there is a quality of the gas issue. Flow fuel into a glass jar and look at what you get, water will be at the bottom if you have any. When was the last time the filters were changed or cleaned? What does it do under load? There's another post and it refers to how the majority of fuel problems are actually electrical.
hello eman85 , which filters are there? thanks Bill
Did you try adjusting the low speed jet just a little? With no load it would still be dependent primarily on the low speed.
